I Love Antec Psu's!!!!
ok, check this. I have a 430w antec PSU, which i acidentally plugged the floppy drive power cable in wrong and it shorted out the floppy drive. ALot of magic smoke and i ended up cutting the floppy connect off along with 1 of my 4 pinn connectors and my PSU is still running strong. Even after that incident check what im still running on my system
MSI K7N2 Delta-L w/ Barton 2500@3200
ATI Radeon 9800pro
1gb OCZ EL Platinum pc3200
4x80mm case fans LED
120mm fan LED
90mm fan LED
Tt Light tube
Front LED of my case
Temperature LED
DVD Burner
160gb Seagate Hard drive
60gb Western Digital hard drive
I dont care what other people think, but for having alittle damage done and -1 4pinn rail. This PSU is whooping my a$$. (then again for 69$, it should come with lights and be able to talk and dance. :D )
Is this the same Antec you own that blows the air in reverse? As you outlined in the other thread?
not backwards. Pluged in the prongs to far to the left and power went to ground instead of red>red. it went red>black.
edit: yea thats the exact PSU i have.
I have that one as well, except bestbuy sells it for 99 not 65, bastards :rolleyes:
