Aceharding
- Dec 21, 2006
None of them work for me.
I installed Windows XP w/ SP2 on a new, well not really NEW, but a reformatted drive and it's saying "Error loading OS".
It WAS "Error Loading Operating System" before I ran WD's Lifegaurd program on it and tried to restore the MBR. The jumpers are in the correct place as with the ribbon config. (Master [Hard DRive] on the grey [middle] and the Slave [DVD drive] on the black [end])
I've tried using Windows Recovery and did fixmbr and fixboot but they don't work. I've tried accessing the hard drive through Auto, Large, CHS, and LMB. (Or whatever they are)
I've tried reinstalling it on another drive but I get the same message. I've tried reinstalling it on the same drive, nothing. I've formatted that hard drive like 3 times already, doing quick installation as well as full format. I've deleted the partition beofre I installed WIndows, I've kept the parition beofre installing Windows, they both don't work. I can't install 2k then upgrade because I don't have 2k. I've updated my BIOS to the latest version as well.
I've installed WIndows using the 6 boot disks, I've tried Installing WIndows with the CD. Both a no go.
The only other solution that I've read up on is to fill the hard drive with 0s. But I can't seem to figure out which program to use. ANy help here?
Oh btw, my motherboard is A7n8x -x
