I was wondering how my score was...5694 I couldn't compare system because I was only using the demo. This is my first run with 3dmark03. My 3dmark01 scores is in the sub 16k. Thanks
We have matching scores lol. You do not say but. Do you have your CPU and Vid card overclocked any ? If not like the other guy said I am sure you can get a higher score easy. Imself have mive overclocked to get this scroe and hope to get it higher before I am done. I have seen others with just about the same system specs as me with a score of over 5900 or higher and that is what I am shooting for myself.
3dMark2001se seems to be alot more cpu dependant then 3dM2k3, mainly FSB improvements raise your score and 3dm2k3 seems to be more videocard dependand as a faster cpu got me a small increase only.
i get a 5530 with my specs. i think the ram is really holding it back. a friend of mine had his ram in non-dulechanling form and got a 5230 with a 9800 pro and then put it in duelchannel and got a 5620. i wish my mobo could take better ram
I'd also like to say Norton AV is running along with about 26 other processes I would use while gaming! Which I think is only fair. Do you guys shut down every unneccessary process while benching?
