OOPS.
It was an AMD xp 2600+ t-bread on an asus vt8x-x (via), using a special cooling thing I invented called Dutch winter (3 case fans and the comp is sitting next to an open window with 0 degrees celcius outside).
I changed the multiplier from 13 (where it worked fine) to 13.5 on fsb of 166 and vcore of .8 (the original tbread multiplier is 12.5).
after running cyberlink's producer for 20 seconds (highly cpu consuming), the comp just turned off and it doesnt turn on again (i get the green led on the board but nothing besides it).
Im guessing the cpu fried, I hopw they will replace it on the warranty.
R.I.P
p.s. I see onlline that now they only have bartons, how do they compare to the tbread 2600+ in terms of OC?
R.I.P
