i keep cracking reservoirs!!
johnzm
alright i got some pics of my mounting, becasue im extremly irritated about this..
the first one cracked on the top barb fitting. this one on the bottom...
*copy/paste in new window plz*
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wMjM5ODQxNnM0MTNkZmQzMXk1NDE=
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wMjM5ODQyNnM0MTNkZmQzMXk1NDE=
i have no clue how to fix it! u think my tube angles are causing a great deal of stress on the resivoir? i hardly ever move the computer so it isint anyhting like that.
plz gimme some pointers
Heat up your tubes in hot water for a few minutes and bend them to proper angle. Then let them cool, keeping them bent. It should stay close to the way you want it. Should help reduce the stress the tubes are putting on the res. Works with the vinyl tubing I use in my fishtank. Probably should work with the Tygon R-3603 you're using.
Or you can use elbows. Not the nicest solution but it will work.
