I just got this temp probe, how do I mount it?
Well, to get the BEST reading you'd need to pull the heatspreader off the chip. But the risk of crushing the core goes up quite a bit.
I've had a thermal probe just taped to the lowest point of my heatsink for a while now, and its pretty worthless like that.
Tonight i'm going to take it apart and attempt to secure the probe to the side of the heatspreader with a few dabs of superglue and see how effective that is.
Well if I had a heatsink this probably wouldn't be that hard, but Im not using a heatsink, I have this hugh phase change evaporator head on my FX55
well forgive my ignorance of phasechange systems, but since the point is you need CPU temp, I don't see how that changes anything. Anywhere you can stick it closest to the CPU core would be best, right?
I didn't mean for it to sound ignorant, take it easy buddy.......
