I have recently purchased the Hauppage HDPVR. I have found that it has serious lag times when changing channels. This keeps WMC from being able to record TV shows and it's just a pain in the butt.
I noticed that if I change channels with the cable box remote that the channels change in under 2 seconds (probably just encoding and USB latency time). This leads me to believe that if I can configure my old IR blaster that came with my HTPC as the channel changing device then all will be right in the world.
The only problem I have is that I don't know how to tell WMC to use the older IR Blaster for channel changing. Does anyone know where this setting is held? Registry somewhere? Media center config files?
I'm running windows 7.
