ok so I have done a lot of research and come down to the following
P35
Abit IP35 pro
GigaByte GA-P35-Ds4
X38
Asus P5E
Gigabyte GA-X38-Ds4
There have been other boards that I like, but for some reason or another they always have some sort of problem. I have not really decided on p35 vs X38, I honestly don't care much. I don't game to much anyway. What I seek is Stability, and a High Quality product. I want to Buy a Motherboard and I want it to work. No DoA or dying in a few weeks. This is why the majority of the Asus P35 boards scare me. There Most Expensive boards seem to be their worst. Also I want Raid 0/1/5/10 on my ICH9R, preferred matrix, but not needed. So the P5K-E and Premium are the only boards with this, but they suck, according to most places.
So I came up with the small list above and think I looked at the majority of major suppliers. Asus, Abit and Gigabyte. My criteria is pretty easy. I want the integrated raid 0/1/5/10 and the Ability for stable over clocks. I want it to just work with my E8400, a bios upgrade is ok, but i still need it to boot, so I can do the update. I am away at college and don't have access to another cpu.
I have already Chosen to go with the Intel E8400, a nvidia 8800GT and 4gb(2x2gb) of most Likely OCZ or Mushkin, not sure about G.skill. Doesn't sound very reputable.
My max to spend is $240, I don't mind spending it, but I want the least number of problems. Also I have never personally used anything but asus, so if I don't choose them, I'm a tad worried.
P35
Abit IP35 pro
GigaByte GA-P35-Ds4
X38
Asus P5E
Gigabyte GA-X38-Ds4
