I have looked for so LONG!
fusionrs
Ok so I upgraded my old Sony Vaio PCV-L620 to Windows Server 2003. Everything is great yet I want to use the onboard sound and I can't. I believe it is the Aureal 8810. I think one of the file names I need is adm8810.sys I can find the drivers for Win2k, 9x and everything under the sun but 2003! Please help me find them.
Alright so I just put Windows Server 2003 Enterprise edition on my old Sony PCV-L620. Here is one of my problems. I have a built in sound card on the computer. It is a Aureal 8810 I believe. I am looking everywhere for the Win2k3 Drivers. I have tried the XP, the Win2k, and 9x drivers and none of them will work. I installed my Soundblaster in the computer and it works fine for now. Here is my problem though. When I am remotely connected to the server and try to play an audio file it will give me this error here.
Also in the control panel under sounds I am getting the Microsoft RDP Audio driver...
Well quick rundown I want to be able to stream Audio using the remote desktop but am hindered because of the error and other reasons unknown to me. Also I am looking for the Aureal 8810 drivers for Win 2k3 Server. I found this here http://home.triad.rr.com/faq/WNS2003 FAQ.htm which says "Listed below are the drivers that were removed. These are currently
planned to be available from Windows Update :
adm8810.sys - Aureal audio device
adm8820.sys - Aureal audio device
adm8830.sys - Aureal audio device
admjoy.sys - Aureal gameport device
aztw2320.sys - Aztech audio device
ctlsb16.sys - Creative SoundBlaster ISA
cwbase.sys - Cirrus Logic ISA audio devices
cwbmidi.sys - Cirrus Logic ISA audio devices
cwbwdm.sys - Cirrus Logic ISA audio devices
ds1wdm.sys - Yamaha DS-1
es1370mp.sys - Ensoniq ES1370
es1371mp.sys - Ensoniq ES1371/73/CT5880
es1969.sys - ESS Solo
ess.sys - ESS ISA audio devices
maestro.sys - ESS Maestro
nm5a2wdm.sys - NeoMagic NM5
nm6wdm.sys - NeoMagic NM6
opl3sax.sys - Yamaha OPL3 ISA audio driver"
So it is available from Windows Update so it says...But windows update isn't finding anything...Please help I am at my Witt's end with this nonsense! Thanks alot.
Alright well I finally found the driver I needed and AM still getting that friggin error. Everything is now installed right and the sound works fine on the server just not when I am Remotely Connected...What could it be?
