TechLarry
RIP [H] Brother - June 1, 2022
- Aug 9, 2005
And it has me totally baffled. This is my home network and I work from home.
Symptoms
File's I'm downloading are stored on a corporate gShare.
When download a large 10GB file from the corporate network, over VPN, about 30-75% of the way through the download my network goes dead. No computers have access, Tivo's fall offline, phones and iPads drop off line, etc... Tivo's are hard wired, computers are hardwired, iPad/Phone's are wireless.
Everything drops offline at the same time. It happens every single time I attempt the download.
I have NO problems downloading 4+GB ISO's from TechNet, or any other downloads.
I can move hundreds of GB of data over the network to my Server 2012E box with zero issues.
Here's an interesting point. Once this happens, I can't reach my Router's internal web server (192.168.1.1) it does not respond, from ANY device on the Network. A quick reboot of the router will not resolve the issue. Now, I know what you're thinking, because I did too. But hang in there...
Equipment
What I've tried
Analysis
Conclusion
None. I'm totally frickin' stumped at this point.
The only way I can get it back online is to power off everything (computers, router, switch, cable modem, etc...) and let it sit for 20 min or so. I can then light it all up and it's like nothing every happened. Unless I try to download the files from that gShare again.
Symptoms
Equipment
- Cox Cable, 30/4.
- Cisco Docsis 3 Modem.
- TrendNet 16 Port Switch.
- ASUS RT-AC66R Router.
- Cat5e and Cat6 Cabling.
- Standard Desktops and Laptops running Windows 7 and one running Windows 8.
- Wireless only used for phones and iPad.
What I've tried
- Thinking the router may be overheating and locking up, I swapped in two backup routers. A Netgear WNDR-3700, and a WNDR-4500. The problem repeated exactly as it did with the ASUS.
- Replaced all cabling.
- Bypassed the switch by plugging everything directly into the Router.
- Used a chicken foot to throw pigs blood on the office wall. Well, not really, but that's next.
Analysis
- If the problem was the Router, it should have been resolved by the (twice) swap-out of the router.
- If the problem was the Switch, it should have been resolved by the bypassing of the switch.
- If it was the Cable Modem, it should not affect my ability to hit the internal web server of the Router.
- If it was a cable, it should have been resolved by the replacement of all the cables.
Conclusion
