But I need some help. My comp is idling at 45 degrees and load at 54c or so....mainly after the water temperature is stable(so it takes the comp 3 hours of startup to idle at these temps).
I want to buy a bigger reservoir for the system but it uses 1/3in diameter tubes...the ones I see online are usually 1/2 or 3/8. Can anyone help me with this?
I am about to put a 120mm 115cfm fan onto the pump for extra cooling, but I think a bigger resevoir will help the most.
