videogamer323
- Jan 31, 2003
About to start working on a new watercooling setup and I have a few questions since I have been out of the loop for awhile.
D-Tek Fuzion
GPU Block (maybe x2) (Probably some sort of EK one once I get my new videocard(s))
Chipset block (once I figure out if it is needed)
Thermochill PA120.3 Radiator
Laing DDC or Laing D5
2x Thermochill PA120.3 Fan Shroud
6x 120mm Yate Loon D12SL-12 Case Fan - Black (47 CFM, 28 dBA)
Going T line and trying to make this build pretty silent so all fans will be on controllers. Radiator will be mounted on top of the case.
Ok so the questions I have:
1) Which pump would better serve me? The Laing DDC w/ Petra'sTech DDCT-01s Top or Laing D5? I was looking at the GPH and Head pressure both have good and bads. Which would be better for the setup above?
2)Would 2x fan shrouds be overkill? Remember I want as little airflow to keep everything silent so the more efficient it is the better.
3) Is it ok to use elbows in the loop?
4) Anything you see just absolutely wrong with my setup?
Thanks for all the help!
D-Tek Fuzion
