Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
The production you did have is greatly appreciated. Please do stay active in the forums.
Just a suggestion for your lappy. Assumption: Dual Core. Try running the Console (non SMP client) on each core and use 75% of each core. This will prevent it from running at full bore and will reduce the heat. You'll still get production without the heat. You can play around with the utilization to find a temp that is comfortable to you.
