I have a big head...
bobsaget
Being 6'5", I have a big head! :p
I think I might wear like a Size 8 1/4 hat...
I was just wondering if most headphones would fit on my head?
Thanks :D
Whoa, you do have a big head :p . I would say yes, if you get a pair that is of higher quality. My head is 7 1/4 and I use the second notch on my headphones and it goes up to 10 notches (that is huge too, probably a lot bigger than your head).
Best bet is decide on the headphones you want, then try them out at a local store.
Grado's will fit anyone's head... it's insanely adjustable. And they pwn Zalman.
