I hate you guys...
DudeItsMe
For being so right!
Summer is closing and that means my 2nd self-built computer. Definetly wanting to do some interesting modding for this one. Anyways after being "decided" on a case for a month or so (Praetorian 730), I admitted to myself that it was going to be too difficult to sand the front of it and it just wouldn't work in the end with my plans.
So I looked at all the Lian-Li, Silverstone, and Coolermaster cases... still nothing. Although I currently own a Lian-Li and love it, many of their newer designs just seem too complicated inside with all the various stuff going through the case. I was getting discouraged and about to start a "help me choose a case" thread, when I remember the Antec P180.
And now I'm looking at gettin one of them. So far, everything looks like it's going to work out fine, although the painting may be a bit tough. I'm thinking that it can be done fine if I put the planning into it. Most likely, I'm going to order the case from Newegg soon and RMA it if I don't think my mod is workable. It's tough to say I want to put hours and money into a case when I can't see it in person.
So here's my plans for the case:
1) Side window. I like the bolt on look with the trim, so I'll likely be going that route
Link
2) Paint exterior. I'm thinking glossy white, with the black plastic on the case possibly being a different color. I'm thinking red or green.
3) Paint interior. I'm leaning towards a hammered red right now, but I may go with a normal red.
4) Interior dress-up... lights, cable management etc. Whatever is necessary to make the job look good.
Anyone have any comments or ideas? And a review that was done recently would be nice, since the P180 seems to have had a few changes since it was first manufactured. My main concerns right now are how hard will it be to paint the black plastic exterior, and how hard will it be to paint the interior (to what extent can the case be disassembled?)
Thanks in advance for any comments/help :D
Obi_Kwiet said:
Summer is closeing? What?! It's the middle of winter!
Winter is the time I spend looking forward to summer... even wear shorts 90% of the time... obviously something wrong with me!
But yes, when you get the urge to build and mod, it's never too soon to start planning!
OOOOHHHHH.... He means summer is Closing IN!!!
Ok I get it now. If You are looking to mod something why not go with a classic, the Antec/Cheiftec Dragon. Now I know there are those of you out there saying its been done too many times before, but the reason is that you cant go wrong with a classic. Dragons are very stable, easy to use, have plenty of room and go for about $70 if that on the internet. My suggestion would be to see if you can put your own spin on an old classic.
Just my 2cents though.
Dillusion said:
in FL we wear shorts 24/7 :p
Liar, but you're in Orlando. Might make a difference. I'm stuck in Jax.
Anyhow, if you're going to get a P180, for the sake of Jeebus, get the black one!
http://www.endpcnoise.com/cgi-bin/e/p180.html
Pure pwnage. Almost as good as buying a TJ-07 or CM 830. Almost. ;)
EDIT: Oh, btw, I have the same problem picking cases as you do. I spend MONTHS picking out a case. That's why I'm starting a case review site, lol... :rolleyes:
The Dragon might just be too hard to paint. If I wanted the Dragon style, I'd go for that Ultra case with the nifty wire hiding stuff it had. Reason I say too hard to paint is that front design... having to sand all of that
mmm the front isn't really all that bad for sanding on the dragon. :) but ntl I like your ideas for the p180 so far :) hope to see a worklog in the future ;)
It was -10c where I live, I'm wearing a T-Shirt, and when I went to school I wore a Sweater, shorts are easy, legs don't make you cold.
Exactly... legs don't get cold and the arms can take quite a bit. Really, it's the wind that gets me. If it's 10 degrees and no wind I feel awesome.
As for the worklog, I hope to see it someday too
haha im even WORSE than you with cases. I buy a new one every month, and i mod cheap ones for fun.
Actually im working on one right now. Gutting the ribbing down at the base and going to replace it with something that front isnt all that hard really. Looks difficult but just needs some planning. Like anything else just take your time and plan it out before hand.
