I hate my computer so much.
mpeg4v3
So today I go to try out a little UT2004 to test the new dedicated server I just put up on my file server. I play for five or so minutes, it crashes and freezes my computer. I reboot, try again, it does the same thing. I try downclocking my CPU to stock, underclocking my memory, and running my vid card at stock- each different try results in in the same thing: crash and freeze.
As I come back up from a reboot, the system goes EXTREMELY slow. Until I move my mouse. I quickly find out that the ONLY way to get any response from my computer is to move my mouse. WTF?!?!?! How the fuck does something like that happen?!?! If I click the Firefox window, then leave my mouse still, the window won't open on the screen until I move the mouse. I manage to open UT2004 again, and 3d works perfectly. Of course, it results in a crash and freeze again, but that's a given.
So I reboot into safe mode. It doesn't do it. Driver issue I say. So I completely uninstall all of the ATI drive suite, and I mean completely. I hand-searched the registry for keys. I followed every ATI drive removal guide out there and used Driver Clean. Reboot into normal Windows, and it works fine. Install the latest Omega drivers, which are newer than my old set, and reboot. AND IT FUCKING DOES IT AGAIN!!!! ARRRRRGHHH.
At that point I had had enough of my computer. Reboot, boot off CD, rename Documents and Settings & Windows folders to something else, re-fucking-install Windows.
And I proceed to spend the next two hours downloading all of the drivers and software I need, as well as copying over everything from the old install. I then install all of the drivers and service pack 1 in one boot, and reboot. The WinXP boot screen comes up, then goes away. All I see is a black screen. Then the computer reboots. And continues to do the same thing. Over and fucking OVER. I try Safe Mode. Same thing. I try Last Known Good Configuration. SAME FUCKING THING. Once again: ARRRRRRGGGGHHHHHHH. I fucking hate this piece of shit.
So here I am, a good four to five hours after my initial problem, reinstalling Windows for the second fucking time tonight.
I really hate this piece of shit computer.
wow, I would hate that thing too...
That mouse thing is wierd. I have no clue as to what is causing that.
Then the screen going away upon rebooting.
I might guess it is your hard drive, but I really have no clue at all :( sorry
good luck on fixing it! :p
Wow.
Just fucking wow.
I just reinstalled the Omega drivers on my second install...
... AND IT'S DOING THE SAME FUCKING MOUSE THING AS BEFORE!
GAHHHHHHHHHHHHHHHH
Fuck this piece of shit. I can't believe this. At the rate this is going I'm gonna sell all the fucking parts and get rid of this thing because I'm fucking tired of it always fucking up for NO god damned reason.
You may want to try a memtest first but it sounds like somethings failing, since its not showing up until you install the drivers id start with the video card, uninstall it and see if its still giving you issues, if so, id move to sound, then nic, then whatevers left. If none of that solves it, id start disabling ports in the bios. Again if that doesnt work, id start yanking extra drives, if that still doesnt work, then you're pretty much narrowed down to PSU, Processor and motherboard.
mpeg4v3 said:
Wow.
Just fucking wow.
GAHHHHHHHHHHHHHHHH
try not using hacked drivers.... :rolleyes:
stop cussing so much if you want help. wanna rant? go to GenMay.
and its an IRQ conflict, would me my first guess.
Im not going to edit your posts or start censoring members here but a little less cussing in this particular forum would be nice ;)
A friendly suggestion from your local neighborhood mod.....
