jerryrigged
- Aug 10, 2006
Hey all,
I cannot get this "asus update" utility to even install. I download the program, it opens up through winrar, there are two .exe files, when I try to open either, I get a message telling me no ASUS motherboard is detected!
This computer is running on a p4p800 Deluxe!
Any help would be awesome.
Thanks.
If anyone encounters a similar problem in the future I found the guy's post who found the solution over at "tombraiderforums" lol
Here is the link: http://www.tombraiderforums.com/showthread.php?t=64047
The excerpt above is from the second page.
Now, can anyone link me to a good (meaning it still works) vmod/vdip tutorial for the p4p800 line?
Thanks!
Thanks.
I have finally found the solution to this problem.
Open Registry
(Click Start > Run... type in
regedit
click OK.)
In the left side of the menu, navigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node
Change the name "Wow6432Node" (right-click on it and select "change name") and put a low case "a" in front of Wow so that it will become:
HKEY_LOCAL_MACHINE\SOFTWARE\aWow6432Node
Reboot the PC.
NOW install ASUSUpdate.
Thanks!
