I Guess It's Full - Silverstone TJ08
Fooshnik
The Powercolor Myst on the inside was getting far too hot, so I added an Antec 620 to it. There wasn't much room with the Zalman and HD cage in there. This isn't going to win any "clean install" awards.
It works surprisingly well. Before the inside Myst would get up over 90C in a few minutes and start to smell, now at most it rises about 7C and holds for the duration. The hot air blowing through the CPU radiator hasn't been an issue as when the video cards are used (gaming) at most two cores of the CPU are in use, when the CPU is in use (video editing) the video cards are not.
There doesn't appear to be room to add a second 620 to the other Myst.
the rads are very interesting indeed.
If you switch to SSD you could remove the drive cage and have room for a push/pull for the smaller cooler. Though that would be a bit expensive to do.
btw, awesome cable management
I don't think stacking rads falls under the standards of "good practice", but even when running the video cards and CPU full blast (mining, folding) the CPU only goes a little over 70C @ 4650.
There's two Corsair M4s, Raid 0 under the platter drives. That's about all I can put in this case, all the SATAs are full. I'm actually impressed with the amount of stuff you can squeeze into this case if need be, and still get the cover on.
Here's my Lian Li V354. It's no where near as functional as the Silverstone, though in my opinion it's better looking.
If I had to choose between the two, I wouldn't.
Honestly the TJ08-e is one of my favorite cases.
I'm not sure I'd call it SFF, but it's an absolutely fantastic piece of work.
