revenant
[H]F Squad Captain
- Apr 10, 2005
... it's smaller in person than it looks in movies.. uhm, er, pictures and youtube videos. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
some fast-n-crappy pix
the good:
* it took all of 45 seconds to be synced up and ready to roll after I turned it on (I had my contacts polished off in gmail tho)
* it's a very good size, about the same as the iphone just a little thicker
* great call quality for me and the other end
* 3G browsing is super fast, the browser is very nice also, snappy and easy to use.
* gmail and gchat work great, well integrated.
* the KB rocks, takes a little getting used to but I love it over a virt kb
* the gps works great, but drains the batt pretty fast, keeping it off unless I am using it
* the notification bar is awesome... stuff happens and it stays there until you are ready to pull it down and see what's up.. you don't have to wait for downloads to finish, you don't get interrupted when you're in the middle of something by another event. very cool stuff
the bad:
* the dialer is very "meh" and it doesn't make use of the accelerometer (which is in the phone) so like when you're checking VM you need to pull the dialer up after you move the phone away from your head..
* the SD card just sometimes is unreadable and needs to be re-inserted. which is kind of annoying. I am guessing a firmware fix for this will happen as others are reporting this also
* needs a virt kb so you don't have to pop into landscape mode every time you need to type in anything (this is coming via the marketplace)
* no easy way to make the phone go into silent mode quickly.. EDIT: doh.. figured this out, just use the side button to turn the vol all the way down. *doink*
* the screen gets smudged easily.. it's not as easy to clean as the iphone's glass screen, but it does polish up nicely with a cotton shirt.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
* the build quality feels a little more flimsy than I had expected, but after having a 2G iphone for several months, that's a tough act to follow.. the more I use the G1 the less I think about that now..
(edit: I guess I am comparing this to the iphone a lot, but that's what I was using last)
well, that's kind of it for now.. no deal breakers here.. it's a really nice device. browsing and chatting and emailing is so damn easy... the touch screen is great.. android is very polished and easy to use.. it seems to behave more like a PC OS than a any previous smart/pda phone OSes I have used before.. the music player works well, nothing fancy, but it good and the audio quality on my Shure earbuds is very nice..
Anyways, I need to play with it more.. I was so zonked last night I didn't spend as much time with it as I had hoped.. Oh, one more thing, the marketplace is very sparse atm, I guess they cleaned it up for launch, so a lot of the apps were removed, but are coming back...
![P1010318.jpg](http://i36.photobucket.com/albums/e40/r3v3nant/P1010318.jpg)
![P1010320.jpg](http://i36.photobucket.com/albums/e40/r3v3nant/P1010320.jpg)
the good:
the bad:
