i noticed a few things during this last upgrade round, so i'll illustrate.
system 1 - shuttle sn41g2, axp 2500+, 1gb corsair ddr, r9800pro
system 2 - shuttle sn85g4, a64 3400+, 1gb corsair ddr, r9800pro
system 3 - shuttle sn85g4, a64 3400+, 1gb corsair ddr, 6800gt
ok now when benchmarking using 3dm2k1 i got
sys 1 ~ 14000
sys 2 ~ 20000
sys 3 ~ 22000
so when running older type games it seems like a 9800pro is good enough and a cpu upgrade will do well.
when benching 3dm 2k3 i got
sys 1 ~ 5100
sys 2 ~ 5300
sys 3 ~ 10400
so when running the newer games it seems like they are not cpu bound but gpu bound instead.
playing morrowind, making a run through balmora @ 1600 x 1200 w/ 4xaa & 16xaf i got
sys 1 ~ 15-25
sys 2 ~ 30-40
sys 3 ~ 40-50
so playing morrowind, the gpu and cpu upgrades seemed to work out around the same.
so it would seem like if you're playing slightly older games then using a 9800pro will remain a good investment. if you're playing newer games then a gpu upgrade will do much better than a cpu upgrade, so even running a slower cpu you'll be fine in getting a new card.
overall i'm glad i upgraded everything, now i can quit adding things to my wish lists for a while.
sys 1 ~ 14000
sys 2 ~ 20000
sys 3 ~ 22000
sys 1 ~ 5100
sys 2 ~ 5300
sys 3 ~ 10400
sys 1 ~ 15-25
sys 2 ~ 30-40
sys 3 ~ 40-50
