CyberJunk
- Nov 13, 2005
I have a visiontek 4850 and i had been experiencing the same problem alot of people have with the card shutting of and going to a black screen and the driver failing. This was due to the card overheating well specifically the VRM's well this what i did. Instead of buying another cooler all i did was just take apart the stock cooler and removed all the junk from the factory. I think the problem is that they put theses thick adhesive pads for the rams and more importantly the vrm's. The ones for the Vrm;s like sufficates them and must reduce the airflow. Well anyways i removed all of that crap and cleaned off the GPU and put on some AS5. Now my card at 45% fan speed doesn't get any more hotter than 72c ive seen and more importantly its not shutting off
So i recommend doing this before buying aftermarket coolers.
its really easy to do and i think it makes a big difference
