I dusted.
AMDXP
No where to put this put I dusted my computer Yeah! 31*c vs 35*c idle yeah!
Me too, actually. My temps dropped a couple of degrees, but mainly it just looks better. :)
Let's make your thread fit here.......
hmm.........
No, I don't know where you can get a freeware dusting program, but maybe it will be included in Microsoft's Longhorn......
......especially since someone else came up with the idea first. :D
You gotta vacuum ur comp out and then spray in some oven cleaner and scrub it out with a wire brush till its all nice and shiney. I guarantee ur temps will never go above ambient again.
are you serious or just messing with us? oven cleaner sounds bad
If mentioning 'oven cleaner' didn't give the joke away, then 'wire brush' might do the trick. 'never above ambient again' is just a polite way of saying that you just brutally murdered your hardware if you were foolish enough to try the 'cleaning' method he described :D
ah but I do :p
Dustbuster havent tried that particular version, Im still on 2.6.2 w\ W2K, guess I better download the latest
now what do we do with this thread?
move it back to software :p ?
