i dont know where else to post this..
wo0ow
when u right-click the mouse a menu shows up with some options.. (im sure u know this..) is it possible to add another option.. lets say.. something like.. "Games" :rolleyes: so when i move my mouse to that an extention comes out and showes me the list of link that i give it when creating this menu thingy.. if its possible..
my under windows XP
First of all, what the hell are you talking about? I have no idea what right-click menu you are talking about. Where are you right-clicking? Just about everywhere you right-click there is a different menu.
He's talking about adding programs to the Desktop context menu - he wants to add a Games menu option which contains a list of programs installed on his computer, so he can launch it from there rather than the Start -> Program Files button.
Yes there are ways to do this. I don't remember any offhand, they involve downloading programs which modify your context menu so you can add programs, actions, etc.
EDIT: Actually yes I do know one offhand, it is called Quick Menu. Google for quick menu or the type of program that does this, which is called a "shell extension".
- Qualm
um... what exactly does this quick menu program do and how do i use it? and is there any other programs that do this? (without C++ if possible)
Any other programs to do it without C++?
What are you talking about?
about the c++.. i searched for shell extensions and i got a lot of c++ scripts..
Qualm
thanks again! that works perfectly.. the program i got before was quick menu builder... i have no idea what it does..
this one works great! thanks again
You're welcome :)
The reason you get search results for C++ scripts is because most shell extensions are written in C++. Mainly because at the level of techno geekness you need to think about writing shell extensions as a hobby, you find C++ programmers.
- Qualm
