I did something really bad, please help me omg :(
Kurak
Ok, I was noticing poor system performance. I had switched from an nf7s motherboard to an asus a7n8x. I didn't have to reinstall the nforce drivers b/c the chipsets are very close, but I decided it would be a good idea to.
I ran driver cleaner and then ran the set up program.
Now, whenever I restart I can't get windows to load, not even in safe mode. THe monitor just turns off and it tries to start up again.
Help. IF there is any way to reinstall the drivers using a windows cd or drivers that I have on a cd or a floppy, please tell me. Otherwise it looks like format time, and I might lose a lot of my stuff, unless I buy a new hard drive and wait a while for it.
what operating system?
if its windows 2000 or windows XP then its a tad more difficult but you can just swap your hard drive for the CD drive in the system you are using now if its got either of those OSes in it too and just copy your data (but installed programs you will have to reinstall) over. I do that a lot.
This is exactly the reason I use norton ghost 2003. it backs up your hard drive partitions to an image file or CDR/DVDR/CDRW/DVDRW disc or even an image file on a hard drive shared on a network so you can just restore it if something goes wrong. best way to back up IMHO.
use knoppix to gain access to the file system, backup your critical stuff, and then re-install. You probably need a clean install anyway.
Just reinstall windows without formating. It wont kill your files.
but wouldnt the programs have to be rieinsatlled due to teh registry is brand new?
kurak, listen to licks...do a REPAIR re-install of windows and you won't lose a thing...saved my ass a few times
i have done it too but it overwrote my registry and rendered everything useless but still took up space. :rolleyes:
Your programs will all still be there.... just make new shortcuts.
