I cant remove the crappy Emachine left case panel. HELP!
Acidwarp01
I was given an Emachine T4510 and I would like to upgrade the CD in it, but I cant remove the panel to the left side of the case. it is a very flat screw and I dont have anything that fits it. I dont have a set of allen wrenches but could it be that? The right panel has thumb screws, but that damn left side wont come off.
Hey, thanks alot. I tried looking for the guide but the damn page kept giving me errors so I gave up.. Your link worked and I dont need to remove the damn left panel.. There are ONLY two screws and they are both on the right side of the drive. Now i feel stupid.. But thanks alot!
you think you have problems? I unscrewed my HP's left side panel, found it still wouldn't come off.. put the screwdriver where it folds over the back and kept wedging it untill it came off..then found that behind the panel was a solid sheet of metal.. they made it impossible to remove the drives :mad:
