I can't find my second drive.
Gabriel
My second hard drive is detected when I go to Device manager and says it is working properly, but when I go to my computer there is no icon that shows the drive. If I try to install a Game, it only gives me the option of installing to my main drive C:
Both are Seagate SATA 7200RPM drives. I have windows XP.
Please help. Thanks
Do you see it after going to Start\Run\diskmgmt.msc ? If so, right click the unallocated space, create and format a partition, assign it a drive letter, and proceed. If not you've got problems, post as much info as you can about your setup and we'll see about getting it straightened out.
Thanks I figured out the problem. I went to computer managment and there was an option to partition it there.
