I can't boot with a USB storage device plugged in.
NickN
I've started to experience a strange problem. If I have any USB storage devices plugged in, such as my iPod, flash drive, or flash card reader, my computer will freeze at POST and completely stop responding. I've tried all 6 of my USB ports and the same thing happens with all of them. I can circumvent this by unplugging everything before booting up and then plugging it all back in after it's booted up, but it's really annoying to have to do so every time I turn on my computer. Here are my specs:
Chaintech VNF3-250 Socket 754 motherboard
Sempron 2600 (very very slightly overclocked to 1640MHz from 1600)
1GB G.Skill value running at DDR405
PNY AGP GeForce 6600GT
Seagate 7200.7 80GB SATA
Ancient Creative Sound Blaster Live! 5.1
Leadtek TV2000XP Expert TV/FM tuner
Any ideas what might be the cause of this?
Check your BIOS to make sure it's not set to boot off of USB devices first. Probably not the issue, but it's somethign worth looking into.
There's usually a boot from other device option somewhere, not just in the boot order section. Look for that, too.
That or the device if not externally powered is drawing more current than spec'd for the usb port, some devices will do that...
I've had the same problem with little USB thumb drives though, and disabling boot from other devices (or something like that) fixed the problem.
