I can hear myself talking.
NickN
I just got a Plantronics Audio 90 headset. I like it a lot, except for one thing that's really annoying. Whenever I have the mic turned on and I talk into it, I can hear myself talking through the headphones. This is probably a noob-ish question, but is there a way to stop this?
Under the volume control properties box (control panel, sounds and audio devices, then click on advanced) make sure you have the microphone muted (checked) also turn mic boost on. (Yes this is correct, mute your microphone.) If it is in team speak or something similar you will have to adjust the mic volume under the recording dialog as well. Good luck.
When it says volume control at the top, the place where you muted the mic, click on options, then properties, then recording and then OK. You can adjust the mic volume and this will raise or lower your voice volume (what others hear) when using team speak. Also make sure the microphone is selected under this dialog, forgot to mention this can cause feedback as well. Don't forget that mic boost! Good Luck
