This is the first part of of a near complete mod that a friend of mine (bradyapba) and I have been working on. The URL above references complete case and parts which are virtually identical to these from Voyeurmods.com, Danger Den and Crazy PC.
We spent weeks researching the cases alone so I will start here. In this you can see the Lian-Li PC7AW. I have always owned heavy cheaper cases, so this was a pleasure to work with.
The major reasons I chose this particular design was for its classy and elegant aluminum finish, heat dissipation and Lian's standalone reputation. The second was that what I had envisioned for cooling had to fit in a mid-size case and three had to have two 120mm fans. Two complaints about this case however,
1. There should have been more thumb screws that are Lian-Li specific to their product.
2. There should have been a cable management system.
In any case, I made my own cable management as you can see from the dismantled side pic below. A simple bi-metal 1-1/2 hole saw solved that problem. Because our PSU was also longer than normal I had to measure accordingly. Also notice that the top of the case has been removed. This was done by drilling out the rivets, which also made all additional work so much easier. I had originally intended on mounting the radiator to this top panel after laser cutting the 240mm opening with the Aqua Computer Grill over that. That later changed to two Black Ice Pro radiators on each side of the case. I will explain why later and in comparison to Bradyapba's external setup temps later.
Until the next time...
