This thread will cover a few topics I am having with my system so thank you for reading it. Feel free to give advice about any or all of the topics stated here.
I built the following system in my signature for about $1050 over a period of the last 6 months.
I paid the following
CPU- (6 months ago used) - $160
Cooler- $40
MB- $200
RAM- $194 w/ 40 rebate
Graphics card $250 with Arctic Cooling X2
Case- $100
Power Supply- $45
Burner- $37
Soundcard- $18
I have been happy with it except for a few things. They are
1. Temps are running too hot for my likening while at load. I am not sure why because I have a decent cooler.
2. I am adding 2 more SATA drives (4 total) next week and am worried about not having enough juice to keep my system stable at 4ghz. (My x1800XT pulls over 30 amps while at load) I am using the XCLIO 450BL
Specs ->+3.3V@32A, +5V@30A, +12V1@15A, +12V2@17A, -12V@0.3A, +5VSB@2A
3. (Part 1) I want to overclock my ram to get more bandwidth out of it but am not sure how to go about doing this. For example If I run it at 712Mhz (stock is 667) while CPU is at stock and it is Prime95 Stable all day long, does that mean that gaming and windows is going to be stable too? If I put the cpu back up to 4ghz will this make a difference?
3. (Part 2) Adjusting the timings on the ram confuses me and I do not know what to adjust if I get errors\crashes while in Windows,Prime95, and games.
4. While running at 3.75Ghz @1.42V 24\7 My max load temp reaches 66C sometimes which I do not like. Running it at 4ghz temps reach as high as 70C hang around 68-69 most of the time and running 4ghz 24\7 with overclocked ram was my goal with this system. If I plan to keep this CPU for the next 2 years (which it being single core I doubt I will) are those temps ok?
Having paid $200.00 for the Asus P5WD2 Premium and it not being able to run the new Intel CPUS really sucks. Should I just get rid of my 630 and replace it with a Pentium D instead. The 630 is 64bit but I am not even taking advantage of that in XP Pro 32bit because it causes more problems than it is worth(such as with older games). I am wondering how it will perform in Vista 64 bit now.
Notice I mainly play games and multitask on Duel displays in Windows if that helps any.
Cooler- $40
MB- $200
Case- $100
Power Supply- $45
Burner- $37
Soundcard- $18
