There should be no difference.
thanks.
now, why so many people say that displayport is the same as dvi? that there is no difference... people do not know what there are talking about...![]()
as far as i can tell, dvi does not support xvYCC color space, while newer version of hdmi and DP do. So if you have a higher gamut screen (and it looks like you do) than DP can support a higher range of colors than dvi. one thing though
I'm not sure too sure about this, but i believe any non color managed programs will look oversaturated and show unaccurate colors, which is the majority of programs.
i seeI'm pretty sure xvYCC is limited to TV use, high colour gamut monitors that use DVI only such as the 3007wfp-hc, and pretty much every other HCG monitors never list xvYCC.
Either way, DVI or DP will get your colours to look over saturated, unless you use SRGB Emulation.
other q:
which driver should i use? ati site or card maker site?
I'm using a Geforce. I use the DVI port with an HDMI adapter and then run an HDMI cable to my monitor. It carries sound... so DVI ought to carry sound fine if your model of card supports it.
