I am not impressed with my E6600 setup...
BigGreg85
I just built the system in my sig a couple days ago upgrading from a 2.4C with a 6600GT system. To be honest I am not impressed with the difference at all, this system is running the same if not worse than my old system.
This new system freezes completely almost everytime I run 3dmark06 or PCmark05...the one time I was able to run both of those test, I noticed that the frame rates on the CPU test were no more than 2...while on every other video test they were flawless. Could I have a bad CPU?
I have also noticed while using the onboard sound, and when the optical drive spins up, the sound will go out. What can this problem be?
Another thing I noticed that my temps are a little bit high around 45C idle, im used to a 33C idle on my old set up. Would you recommend getting a new case fan and HSF?
Did you do a full re-install of windows?
Are you using windows' IDE drivers or ones from your CD? Uninstall them and let windows use it's own.
The frame rates on my CPU test under 05 are anywhere from 3-5... This is at 3.4ghz so, take this with a grain of salt.
Consider testing your RAM with memtest.
Is it orthos stable at stock?
40 idle isn't too bad for these chips, they have a different sensor than other chips on the market... Just make sure your load temps dont go above 62'c.
Lastly, check the device manager for anything that hasn't been installed, or just isn't working correctly.
silverphoenix said:
2FPS in the CPU test is REALLY good for 3dmark06.
Truth, I'm lucky to get 1 every now and then LOL
Like others have said, is this a new fresh install of win xp? Are all the drivers installed?
WOW, thanks for all the speedy responses.
I am using the 500W Enermax Liberty PSU.
It is a fresh install of windows, and I am using the windows IDE drivers.
The first thing I did when I powered on this new system before I even installed an OS was run memtestx86 1.65+, it passed twice with no errors. What is Orthos? Everything in device manager seems to be installed and working ok.
My main concerns are when the optical drive is accessed or spins up, the computer will either freeze temporarily or the audio will cut out. Also when I try and run both those tests, they system completely freezes on the splash logo, and I have to restart the system.
Orthos is a tool that tests the stability of your system. It runs 2 instances of a program that eats up 100% of both of your processors. You generally leave it on overnight.
It can be found Here
Now, run it and leave it overnight. If it says "STOPPED" in the morning, you know you have a problem with either your CPU, RAM or Motherboard (if you're on stock settings).
I've heard of this IDE CDrom drive problem before, it's honestly not new... I just can't seem to find where I read the fix for it before... It IS out there.
hey there is nothing wrong with your cpu getting 2 fps on the 3d mark 06 cpu test, cpus are not really designed to render 3d graphics that is why we have graphics cards. You should make sure you have installed all the drivers correcty and if your psu is powerful enough to run your new system.
Sorry i didn't see that post that powersupply is more than enough to run that system.
Ok so I was able to run Orthos successfully over night. I have found that I am able to run both 3dCheck06 and PCMark05 correctly, after I disable the optical drive in the device manager.
I will be swapping the optical drive with an old one that I have, to see if it is actually the drive causing the problem.
any other suggestions or ideas?
I'm assuming your IDE jumpers are set correctly right? And that the Jmicron option is set to IDE in the BIOS?
That is common and is nothing to worry about, all my pc's do that to some degree or another, but the audio dont cut out with me, but the computer stutters for like 2 seconds or so while the autorun feature kicks in....
Just for reference, mine doesn't. I notice almost no stutter while auto run kicks up.
2 FPS on CPU is really good. I think I get like 1-3
I have never had this problem with the audio cutting out with any of my previous computers. I will try installing the new Intel chipset drivers....any idea where I can find them?
FYI, are you using the IDE drivers that came with the disk? If so, you don't want to do that. Let it use the default MS drivers that windows will load for it. That's the "fix" from what I understand. I'm using the MS drivers and I have no issues like what you're experiencing... ;)
Ok so I installed the windows standard IDE drivers...and everything seems to be working great.
Thanks for the help guys, and I hope this helps someone else out as well!
Glad that worked for ya dude. So what do you think of the system now? Should be a nice step up from what you had. I went from a P4 3.2Ghz system, with 2GB PC3200 and a BFG 6800U and unfortunately, I can't tell much of a difference yet. I have an E6400, Asus P5B Deluxe, 2GB PC6400 and an XFX 7900GT. I had this chip overclocked to 3.2Ghz, but I was getting some problems while playing FEAR Combat at a LAN party on Saturday. I ended up dropping it back to stock and while it runs fine, it certainly doesn't feel that much faster then what I had. I think the video card is actually what's bad. I put the video card from my main rig (in my sig) into this box and it's running better. I'm overclocking in smaller stages now, trying to tweak it out the best and find the most stable OC. Only at 2.4Ghz now, but hope to get it back up to 3.2Ghz. It'll be interesting to see what my benchmarking shows at that speed... ;)
I was going to suggest this as I was reading down the thread, but it's been done; congrats! Same sort of problem the P5b had with the Jmicron ide drivers (just use windows)
I love this system now!!!...haha, big improvement! F.E.A.R. is playing amazing on max settings. I feel like I cant break this thing at all....and I've tried.
I want to eventually OC it, and from what I remember with my old 2.4C and P4P800DLX...squeezing out an extra 600mhz was cake...
how well do you think I will be able to OC?
OCing to 3 ghz seems to be easy for conroe. go have a look at the conroe OC database in the intel forum. here i only wish i could hurry up and build my new system :(
You've got good RAM and an amazing processor. Those chips will hit 3.0 on air, 3.6 on water, easily.
Your real bottleneck for overclocking is that board. The VM wont hit more than 315 FSB... And to get that high you'll HAVE to set the PCIe bus speed at 110 (not 100 like you're normally supposed to).
Still, 315 * 9 is a good 2800mhz!
Arcygenical said:
You've got good RAM, a good Board an an amazing processor. Those chips will hit 3.0 on air, 3.6 on water, easily.
You see the thing is, I am very noobish to overclocking...when I had my old setup I just bumped up the FSB to 250 and I was at 3GHZ no problem....do you think I will have to mess with the RAM timings or the CPU voltage?
