I AM GOING NUTS
TigerLord
Please apologize the caps... but I'm becoming nuts...
Wait, buy, wait buy... what I now have in my room beside me:
Samsung 226BW
Coolmaster Stacker 830 eVO
OCZ XStream 700W
Cell Shock DDR-800 4-4-4-12
Kama Meter
5x Scythe Mineba 120mm
Thermalright Ultra-120
What I plan to order in 1 week (had to wait til savings were up for the rest):
E6600 Conroe
Asus P5B Deluxe WiFi
Seagate Barracuda 7200.10 320GB 16MB 7200
2x NEC AD-7170S
Creative Sound Blaster X-FI Xtreme Gamer - fatal1ty Pro. Series
EVGA e-Geforce 8800GTX ACS3, 768MB, PCI-Express (the non KO version, as is not overclocked)
But here lies my goddamn dilemma !
I was like ouh, ok, let's get the 8800GTX, then step-up in 3 months for the 8900GTX. However after calling the tech support it seems unlikely the 8900GTX will be released before July 1st (which would be around the 90 days after originally purchasing the 8800GTX). I was suggested to wait...
But then I thought ... well, when the 8900XT comes out, the 8800GTX will be cheaper, so I can buy a 2nd one, run it in SLI. Why? Because, gentlemen (and ladies), what I want the most now, actually more than sex (ok, only one night of sex), is to be able to run Crysis at MAX on my beautiful, new and sexy monitor... I recon two 8800GTX will be able to handle this, and with my current mobo and ram, Im pretty goddamn sure I can git 3.6ghz on that E6600.
But again, here lies my 2nd goddamn dilemma ! The P5B Deluxe isn't SLI compatible ! :mad: :mad: :mad:
I am sure there is an Asus mobo sli compatible, but I think I remember reading it wasnt as good oc'er as the p5b deluxe.
So, fellow hard forum pals, show me the path to deliverance... I'm going nuts! :p :eek: :p :eek: :confused:
asus P5N-E sli 650i mobo?
i think u are over reacting quite a bit lol. possible price cuts coming in april on intel cpus and with the new videocards coming out (8600s, r600) prices will probably fall slightly too (or i would assume). Honestly, prices are always falling, new technology is always 'right around the corner.' If you try to futureproof your system and plan it out too much you will go psycho (not that im calling u psycho or anything ;) ). Eventually ur going to have to pull the trigger.
