Hyundai L90D+ Dvi Display problem
trooper11
Hi, I am having trouble with my L90D+ monitor using the DVI connection.
I can hookup the vga cable with no issues, it shows right up.
when i try to connect the dvi cable, i get no output on the monitor. the monitor power light is blue so its not in standby. i know the system is still running and i tried doing the switch while in windows and even turned off the pc and then switched it. both times the screen stays blank with no output, even though the monitor does not go into standby.
i try using the menu while connected to the dvi cable and the OSD does show up, so i try making sure the digital input is selected, but that doesnt help at all.
my video card is a PCI ATI 9250 and i dled the lates ati drivers. i also dled the drive for the l90d+ for windows. That comes with two color schemes, one for analogue and one for digital. i tried setting it to use one and the ther but that didnt help.
i also looked up the manual for the monitor and tried using the recommended res of 1280x1024 at 60hz, but that didnt help either.
anyone else have a solution to this? thanks.
should i turn off the pc, switch the cable and then hit reset in the monitor menu? or does it matter?
also, where is the reset option? i dont see anything called reset in the OSD
i still cant find the reset option. i must be going blind here lol.
where exactly should it be?
Goto the lcd INPUT SELECT menu and select the DIGITAL INPUT, this turns on the DVI input of the monitor.
After that, if you don't have image, make sure that the analogue (old VGA) cable is disconnected and boot the PC to see if it can detect the DVI monitor.
The reset option is called RECALL in lcd menu, and loads the lcd default settings, if you need them.
