Hi all,
I just bought a HP Microserver, which I understand many are using to play around with virtualisation. For those who don't know it's based on a 1.3Ghz dual-core Athlon II Neo N36L processor. It comes with a 250GB disk and 1GB ram. I will be adding my own second 2.5TB disk.
I wish to run multiple virtual machines on this hardware. My OS requirements are:
1) A up to date windows install that will run 24x7 and sees the second disk "natively" (and exclusively if necessary). That is, the 2.5TB disk shouldn't be virtual since it may be taken out to be read by other machines. The "OS" disk can be virtual if required.
2) A very lightweight Windows XP installation that will be turned on and off infrequently on demand. This may have its own virtual disk.
3) A lightweight Ubuntu installation that will run 24x7 that can have a virtual disk.
4-5) An optional two more Ubuntu installations as above.
I'm quite comfortable with using host based virtual machines (VirtualBox mainly), but since many have been using this particular server as a virtual lab I thought I should look to be a little more ambitious. My questions are as follows:
1) Based on the above use, is there a particular recommendation of HV technology? From what I read, both ESXi and Hyper-V R2 work relatively well on this hardware.
2) Probably an obvious one, but I presume I'll have to upgrade the RAM. Rather than going for the most I can afford (which is 8GB I guess) what's the minimum I can get away with?
3) Seeing as I have a "main" virtual machine, should I just stick to a Windows install and run the XP and Linux installs via VirtualBox etc? What's the difference between Hyper-V and "Hyper-V with 2008"?
