_____ ______
| PCI| | AGP | _________ __________
|____| |_____| | | | |
| |______ | N.bridge|___HyperTransport link_| CPU |
|_________________________| | | |
|_________| |_________|
_______________ |
|__SYS. RAM____|________|
This highway or BUS is an internal connection. On the motherboard level, the HyperTransport bus connects all parts of the motherboard, such as the PCI slots, AGP slots and USB ports to the CPU and memory and also provides the connection between the CPU and memory itself (although it is a bit more complicated than this. The Hammer processors actually connect to memory directly but use HyperTransport to communicate with the memory of other processors in a multiprocessor configuration since HyperTransport is also a coherent bus). At present, the internal PCI bus used in current systems is a rather small road, limited to a small amount of traffic, supporting a maximum data rate of 133 Megabytes per second. This may seem like a lot of data, but when compared to the memory and CPU shoving data around at 2.1 Gigabytes per second and video cards nearing 20 Gigabytes per second, the internal bus is very limiting.
