ok so using cscript hvremote.wsf /show /target:192.168.1.18 gives this output
Microsoft (R) Windows Script Host Version 5.8
Copyright (C) Microsoft Corporation. All rights reserved.
Hyper-V Remote Management Configuration & Checkup Utility
John Howard, Hyper-V Team, Microsoft Corporation.
http://blogs.technet.com/jhoward
Version 0.7 7th August 2009
INFO: Computername is ASSASSINSOFSION
INFO: Computer is in workgroup THEREPUBLIC
INFO: Current user is AssassinsofSion\Ebolla
INFO: Assuming /mode:client as the Hyper-V role is not installed
INFO: Build 7601.17835.amd64fre.win7sp1_gdr.120503-2030
INFO: Detected Windows 7/Windows Server 2008 R2 OS
WARN: The Windows firewall is not active in one or more active profiles.
Not all functionality of HVRemote will be available.
Use 'netsh advfirewall set currentprofile state on' to turn it on!
INFO: This appears to be a server SKU
DACL for COM Security Access Permissions
\Everyone (S-1-1-0)
Allow: LocalLaunch RemoteLaunch (7)
NT AUTHORITY\ANONYMOUS LOGON (S-1-5-7)
BUILTIN\Distributed COM Users (S-1-5-32-562)
BUILTIN\Performance Log Users (S-1-5-32-559)
ANONYMOUS LOGON Machine DCOM Access
ANONYMOUS LOGON has remote access
Firewall Settings for Hyper-V Management Clients
***** Skipping. The firewall is not running or turned off
Windows Firewall exception rule(s) for mmc.exe
IP Configuration
Windows IP Configuration
Host Name . . . . . . . . . . . . : AssassinsofSion
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : TheRepublic
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : TheRepublic
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 00-25-22-DC-92-62
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::79a8:100:c698:e3b6%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.8(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, September 03, 2012 12:41:15 AM
Lease Expires . . . . . . . . . . : Sunday, September 09, 2012 1:44:05 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 167781666
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-57-81-50-00-25-22-DC-92-62
DNS Servers . . . . . . . . . . . : 192.168.1.1
Primary WINS Server . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter VMware Network Adapter VMnet1:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
Physical Address. . . . . . . . . : 00-50-56-C0-00-01
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::3dc9:b156:23bd:65ee%25(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.134.1(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 419450966
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Ethernet adapter VMware Network Adapter VMnet8:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
Physical Address. . . . . . . . . : 00-50-56-C0-00-08
Link-local IPv6 Address . . . . . : fe80::9dbb:dd80:33af:fbdf%26(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.126.1(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 436228182
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter isatap.TheRepublic:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.{B9CB7497-9EEC-4B55-AD1F-13E896D5F410}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{21CF2A4D-A705-4505-9B10-85B13539DBFD}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Stored Credentials
Currently stored credentials:
Target: Domain:target=hyper-v
Type: Domain Password
User: hyper-v\ebolla
Testing connectivity to server:192.168.1.18
1: - nslookup for DNS verification.
Note that failure is OK if you don't have a DNS infrastructure
Server: www.asusnetwork.net
Address: 192.168.1.1
*** www.asusnetwork.net can't find 192.168.1.18: Non-existent domain
2: - ping attempt (ping -4 -n -1 192.168.1.18)
Note the ping may timeout - that is OK. However, if you get an
error that 192.168.1.18 could not be found, you need to fix DNS
or add an entry to the hosts file. Test 3 will fail and provide more
guidance.
This may take a second or two...
Pinging 192.168.1.18 with 32 bytes of data:
Reply from 192.168.1.18: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.1.18:
Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
3: - Connect to root\cimv2 WMI namespace
PASS - Connection established
4: - Connect to root\virtualization WMI namespace
5: - Simple query to root\cimv2 WMI namespace
PASS - Simple query succeeded
6: - Simple query to root\virtualization WMI namespace
- 1 computer system(s) located
7: - Async notification query to root\virtualization WMI namespace
PASS - Async notification query succeeded
INFO: Are running the latest version
2 warning(s) or error(s) were found in the configuration. Review the
detailed output above to determine whether you need to take further action.
Summary is below.
1: Firewall is not active
2: Firewall not running (skipped Hyper-V Management Clients)
\Everyone (S-1-1-0)
IP Configuration
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Stored Credentials
guidance.
Summary is below.
