Hyper-V not pulling an IP from DHCP
Draugauth
Fresh install of Hyper-V
MB Asus P5N SLI
CPU Core 2 Duo X6800
RAM 8GB Corsair
Attempting to use the on-board NIC.
Any suggestions or ideas? I know the on-board NIC doesn't work with Win7 when more than 3GB of ram is installed.
I know you posted to disregard the thread but I'm also using a P5N SLI for virtualization (ESXi) and more than 3GB was nothing but a headache when using the onboard NIC. It would only function sporadically, it would look like its finally working then eventually it would just drop the connection and sit there picking its nose never to reconnect until a reboot. Disabled ethernet in BIOS, threw in a PCI-e gigabit NIC and haven't had any problems since.
Yeah Asus admits that there is a bug with the onboard NIC. And yeah it ended up dieing on me again so I threw in the old 100MB pci nic I had in it before.
