Hyper-V network card problems
alphabanks
Guys I put together a basic Hyper-V lab on Windows Server 2012 R2 in order to learn Hyper-V. The problem I'm running into is network cards. For my ESX lab I use the Intel Pro 1000 PT which works great. I installed a Pro 1000 PT in my Hyper-v systems I am able to use native teaming with no problems it works very well. The problem starts when I create a team and attach the team to a virtual switch. The Hyperv host becomes unstable and starts crashing constantly. So I would like to ask what all Intel or Broadcom nic are you guys using that is stable? BTW I even converted the PT1000 to an Intel I350-T2 and disabled VMQ and SR-IOV still same problem the host crashes constantly. I don't have much experience with Hyperv thus the reason I want to learn it all of my experience is on ESXI. I am shocked that Hyperv seems to be so picky when it comes to network cards.
crash dump
crash dump file: C:\Windows\Minidump\070415-29562-01.dmp
This was probably caused by the following module: e1r64x64.sys (0xFFFFF80085CDEED8)
Bugcheck code: 0xD1 (0x10, 0x2, 0x0, 0xFFFFF80085CDEED8)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\e1r64x64.sys
product: Intel(R) Gigabit Adapter
company: Intel Corporation
