Hyper-V Cluster Question
Hi All,
I am trying to help a small school re-use some hardware and build them an Hyper-V cluster.
I have two HP EasyStore NAS running Storage Server 2012.
I have two HP Proliant Servers Running Windows 2012 R2.
They are only running about 8 - 10 VM's. All very low usage.
I have only built Hyper-V cluster with shared storage using ISCSI. Any pointers on how to create one here? Is there a way to have the data on both of NAS and use a fail over File Server cluster to access them in case one of the NAS goes offline?
With 2012 it seems you can build a Hyper-V cluster using SMB, but it seems to get murky on how to setup the back end.
Has anyone done something similar or have any links I can look to?
Thanks
Matt
In order to create a Scale Out File Server cluster (SOFS) your two file server nodes would need shared disk. Sounds like they each have their own so you won't be able to create a SOFS cluster.
However, you can still have the VMs failover by clustering the two Hyper-V hosts together and pointing them to each separate EasyStore NAS for shared storage. If a Hyper-V host fails, the VMs on it will automatically fail over to the other node.
Another option would be to not cluster anything together and run half your VMs on Hyper-V host 1 and NAS 1 and the other half on Hyper-V host 2 and NAS 2 and replicate each to the other. This would double your storage needs, but would provide the ability to failover should a Hyper-V host or storage node go offline. The failover would not be automatic, it would require you to log in and initiate the failover but you get the added benefit of storage protection as well as host failure protection. Hyper-V replication can sync as often as every 30 seconds so that's the most amount of data you'd lose.
If you go the hyper-v replication route, just watch it closely. When the replication fails, it just stops. There may be an event log or something you can look for.
Once it fails, you have to tell it to continue replicating. Otherwise your VM on the replication partner will be a flashback to when replication stopped.
it's absolutely possible
you need some windows based virtual storage running on your sofs nodes and creating virtual luns with csv on top of them
starwind can do it and also datacore
http://www.slideshare.net/StarWindSAN/ms-scale-out-file-servers-without-sas-jbo-ds
however there's no point in basically wasting two servers
i'd build a 4 node hyper-v cluster and use two hypervisor nodes to run free starwind or datacore virtuaal san software
in upcoming version of windows server there would be storage spaced direct and it would take four servers to create a hyper-converged setup similar to eve:rail from vmware
KISS
