Hyper Transport sync Flood error?
jrrandell
What does Hyper Transport sync Flood error mean and how can I fix it. I looked around a bit and somewhere it mentioned that it is because the Ram is not getting enough voltage. When I looked up the spec for my Ram, that was true it was getting 1.6v instead of 1.65v so I fixed the voltage yet the problem still exist.
It happens randomly, It can happen while cpu and gpu are under stress ( hot ) or it can happen when almost fully idlelike music and web browsing. I have also left the house for an hour so the computer is doing nothing even shuts off the displays and it happens. The message screen always appears.
Anyone know the cause of this problem and a solution, ill list my specs below.
Also nothing is over clocked
MB: MSI 790FX-GD70 running Bios version 1.9 ( 1/13/2010 )
CPU: AMD Phenom II X4 955
Ram: 4GB 2x2 Corsair 1333mhz and 4gb 2x2 G.Skill Flare 1800mhz (currently clocked at 1333mhz )
GPU : Radeon 6870
PS : Corsair HX 1000w
HD : WD blue 640gb sata 2
and a generic dvd rom
also crap load of lights and fans etc but I know that is not the problem my Power supply is over kill =D
Since you are using all 4 memory slots, you may have to up the RAM voltage slightly above stock voltage.
It could also be RAM timings.
Ram timings are all set to stock as far as i know, didnt change them, I ca try and up the ram voltage some more. Any susgestions on how much more voltage? The corsair is only 1.5v ram while the Flare is 1.65v I have my suspicions it is the Ram because I didnt see the error until I added the G.skill Flare ram.
Worst part is i cant really test it since the error is completely random, so i dont know if its enough or overkill.
Edit : also just looked it up, both Ram Modules have same timings listed
Raised the memory voltage to 1.7 but it still happened, so i went in and changed the memory timings from auto to the correct timings. Anyone else have any info to offer? If the problem happens again im next gonna try to up NB and HT voltage see if that works.
Any help would be appreciated tho thx
Edit, got an answer from MSI tech support.
"Dear Customer, Please try remove 2 sticks of memory so that you only have 2 in running in a dual channel configuration. Then see the issue persists under that configration also be sure that you did load the Optimized Defaults in bios prior to making any changes to the bios if not then please do then make any changes you need including the memory voltage just be sure to save and exit afterwards. Thank you, "
Wow thanks for nothing MSI, the whole point of 4 dimm spots is, so i can use them??? And obviously optimized defaults are not working if I have to be in the BIOS at all.
P.S. So far with the timings set to 9-9-9-24 instead of auto is working good. the problem has not arisen yet. But could be just the randomness of the error. ( hopes not crosses fingers )
Also dont know if i will go MSI again, might try Asus or Gigabyte.
swap the ram slots so that the flare is in your primary channel or vise versa. see if that solves the problem. if not pull the corsair and see what happens. still happens pull the flare ram.
due to the differing speeds some ram dont like mixing or want to be in a specific channel slot. its the problem i have with my setup. i have to run my XMS2 in the primary and my kingston in the secondary channel.
the whole point of 4 ram slots is your suppose to use similar ram. yeah you can mix them sometimes but your better off using the same ram 9 times out of 10. cant blame MSI on this one.
it could be the timing's conflicting with each other. its possible your bios was setting the ram timing some where in the middle between what your corsair ram liked and what the g.skill flare liked.
