hydrx with koolance
CUSL2MAN
Could anyone tell me if i can use hydrx with a koolance system? or should i stick with the koolance coolant. I am using a Koolance PC3-725 case.
Thanks in advance,
Robert
The guys at Koolance will void your warranty if you use just about anything but their coolant (trust me they will). If that dosent bother you just make sure you use somthing that is safe for ABS or you might end up melting your reservoir (i have seen it happen)
Thanks for the info ctl alt. with that i think im gonna keep using the koolance coolant.
Thanks
Robert
