Looking for a VESA desk stand for my monitor.
Need a certain degree of portability so I can't use a wallmount (as much as I would like to)
My monitor a Tempered Glass Crossover q27. Weighs in at around 11kg.
Glass and steel are awesome but so heavy.
Basically I want this:
http://www.lcdmonitorarms.com.au/ilift.html
...For less than $469
I already have tried one Chinese one which I had to send back which looked the same as the one above except only $120 and rated at 2-10kg. Monitor just immediately sunk.
I realise it probably isn't something you can/should cheap out on but I thought it would be worth a try to at least bring it into the sub $200.
Looking forward to any ideas or opinions on VESA stands in general.
Thanks in advance!
Edit:Also, I'm in Australia. Though I have no issue buying internationally
Thanks in advance!
