Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am thinking of buying this pump to replace the internal pump in my reserator 1. I was wondering if this pump makes much noise mounted externaly. Thanks
They are very quiet, especially if you mount em to some type of "foam" I cant find the right words. However several people including myself have had horrible issues with the shafts wearing oddly, causing the pump to sound like mini meat grinder. I remedied my buy ordering new impellers. Given todays high restriction blocks though the laing D5 or Swiftech 655 would make for a more future proof, albeit more expensive pump in the short term.
