Hydor L30, Ok when wet?
YARDofSTUF
dunked my whole setup into the sink to get the bubbles out and I'm ready to test it for leaks.
Since I put the whole pump in water is it ok to run or do I need to let it dry?
Thanks.
The L30 is a pump that can be run either submersed or dry so you should be fine.
Yup, I'll second that :)
It's a pond pump so it can be use submerged or inline.
