Hydor L25
It runs on both voltages 110Vand 220V. Even if it has strange plugs, adapters are dirt cheap.
Dont do it! Please consider another pump its took weak for todays blocks. Unless youre into starving your rig of water flow. Ive got 2 Hydor L30's that I'm in the process of retiring cause theyre to weak and dump to much heat.
If youre worried about space looking in the MAg pump from C-Systems, or the Laing 655, or the AquaXtreme 50Z-DC12.
-Brandon
