HX620 Corsair ok for Quad Conroe Q6600?
OblivionLord
I know the Q6600 chip at load can do 130w and fitted with an 8800GTX being about 108w at best according to this Anandtech site that did a power consumption by determining the diffrence in wattage from Idle to Load using 3dmark06...
http://www.anandtech.com/video/showdoc.aspx?i=2873&p=7
thats a total of 239w at full load at best with just both CPU and GPU. Id probably say that you should add another 100w for extra devices since I have just 1 HD, 1 Optical, 6 120mm fans, mobo. That's it
Yay or nay?
Redbeard
Official Corsair Rep.
That hardware shouldn't even stress the HX620 significantly, you'll be fine.
Bbq
King of Charts
The man said it himself; You'll have no problems, and you'll be like OMG <3<3 at the psu. In a non-sexual way.
Or depending on the type of person you are, in a sexual way. :p
