HX-1000W & TJ-09
JediKnight
Im going to change out my current PSU (Galaxy 1000W) with this years upgrades due to a constant false alarm beep. Im looking at the Corsair HX-1000w, Im wondering if anyone knows if the cables on this will be long enough in a TJ-09 (which requires pretty long cables.) The new mobo will be an eVGA 790i FTW (Digital version) ... for 24pin and 8pin cable length considerations.
Im a fiend for clean wiring so I don't want to have a bunch of wires stretched out to make connections, etc.
Corsair's PSU cables are as long as anything out there, so chances are they'll be long enough.
I used a HX-620 for around 8 months with a TJ-09. I would assume since they are from the same PSU family that the 1000 should work easily.
Hey I'm actually considering the exact same thing - except my current PSU is an Ultra X3. I've read a couple of reviews and it looks like the cables in question are more than long enough - for sure longer than the ones on my X3 (I had to buy an extension to run behind the mobo tray). I say whoever pulls the trigger first between us two should post pics here in this thread :)
Cable length was more than adequate for the TJ-09. A very nice and well layed out power supply, very very stable power.
Im changing out the Freezer 7 Pro this weekend for a Noctua NH-U12P though, need extra cooling for the vcore I need to hit 4Ghz. I'll post an updated one once that is mounted.
Looks good . . . a couple more pics of this PSU in the case and I'll likely end up buying it too!!!
Did the 4/8pin ATX power cable reach all the way to the top of the mobo without any problems (I assume you routed it behind the mobo tray)???
Hmm...thinking of picking up the HX1000 sometime soon before my next real build. Anyone know if Corsair has plans to release a PSU inbetween the TX750 and the HX1000? Seems like Corsair saturated the hell out of the 400-750W range but has a giant hole inbetween the TX750 and HX1000.
A 250w gap between the 750 and 1000 is not what I would call giant. Why bother putting out an 850w model when it's only 100w more than the 750 and just 150w less than the 1000w . . . especially when both existing models have established themselves as solid performers?
And even if they had a 850w, would you get it for the $20-$30 less than the $224 most places are selling the 1000w now?
There's just no point.
Because while you can get the TX750 for close to a $100 now the HX1000 is priced at $220-$250 at most places. For some people TX750 is not enough but they're not always willing to shell out $220+ for a 1000W modular psu when they only need a 900W quality psu.
If a person can afford the kind of system he'd actually need a 1000W PSU for, he can certainly afford a 1000W PSU. Not even a high-end quad-core system with two 4870X2s in CrossfireX will max out a TX750, unless it has a ton of hard drives and extra devices.
Yeah the 8 pin runs behind the tray. I don't know what else you would like pictures of, the cables are hidden and zip tied on the two lips around the front fan mount (which has pre-cut grooves for cable ties.)
Here it is with the Noctua mounted, just make sure to mount that 8 pin before that second fan :p
I know you're supposed to mount the PSU that way . . . but . . . have you checked your temps with the PSU mounted with the fan facing up? I have a 4870x2 with QX6850 combo and tried to put my Ultra X3 with the fan down and my temps increased by 6-8*C on both idle and load (46*/80*!!!!). When I put it back to fan facing down, temps went down to 40*/72*.
If I take the side window panel off, temps are 36*/70* . . . which is disappointing because it means circulation is worse with the panel on. I'm considering getting a window panel from frozenpc's that allow you to mount a 120mm fan by the GPU location to see if it helps.
Temps for the video cards?
I've never had a problem with them (or the two 8800gtx I had in there before but that was with a different PSU.) So I haven't reversed the PSU to check for temps.
Both cards are overclocked (have core running 700 stable on them now) and getting high 60's / low 70's on gpu temp which is pretty nice.
I used to have one fyi.. Might still have the window if you want it, its pretty easy to replace the current window.
Unfortunately the TX750 is gimped when it comes to it's single 8 pin EPS connector. I have no idea why you would put out a 750 watt psu that doesn't have the correct connectors to power a dual cpu system. That being said, I own one and other then that it's great.
No, the CPU temps.
I've always had my Ultra X3 PSU installed with the 140mm fan facing up towards the top of the case. In this orientation, it would suck a lot of the hot air in through the PSU and out the back. Resulting CPU idle/load temps were in mid 30's *C/high 60's *C.
Out of curiosity, I installed the PSU the other way (with the fan now facing down) because cable management would've been a little cleaner that way. The PSU now took in cooler air from the bottom of the case (thru to built in meshed vent) and expelled out the back). Doing that caused my CPU temps to jump to mid 40's (idle) and low 80's (load). I was very surprised a simple change like this caused such a huge change in temps.
Needless to say, I put the PSU back to fan up.
True I suppose, although it was designed as a consumer PSU and not really for server/workstation/multi-socket implementations. It's fairly trivial to buy a molex to 8-pin adapter though.
Well I might have to pull this one out, its starting to make a horrid buzzing sound whenever the video cards are under load. Removed each card and tested to make sure it wasn't a loose coil in the cards or anything, its defintely coming from the PSU.
I've also seen strange rail drops under OCCT (confirmed with HWMonitor as well.)
Except since those are software monitoring tools, you haven't confirmed a thing. The only reliable way to test voltages is with a multimeter.
The noise problem is probably a loose coil inside the PSU though. If it's really a problem for you, just call up Corsair and they'll take care of it.
Yeah thats true about using a multi. Haven't seen it with other supplies but with sw software who knows.
Trying to figure it out, still could be cards maybe. I've had it happen on three of them (two origionals and then I had to RMA one of those for other reasons.)
Funny thing is, the noise is super bad when the cards are running in the hundreds or one thousand plus fps only. If I turn on vsynch and keep it at 60, no noise. Happens regardless of clock settings on them too. Its very hard to pinpoint the sound though.
awesome setup man, that looks like it would tear up most games out there. I'm going to the gtx 200 series as soon as nehalem launches
Well, I finally did get the HX1000W PSU and while performance seems to be very solid, the cabling is not as easy to work with as my Ultra X3. The wiring in my TJ09 is considerably worse now than it was with the Ultra b/c the Corsair's cables are longer, stiffer and harder to work with.
I'll spend some more time tomorrow trying to clean it up and if I can't - the Ultra's going back in.
