hum, explain plz
todlerix
what is bank interleave, good bad, enable disable?
so is it good or bad, i read it.. still rather confused ;x
"Naturally, 4-bank interleave is better than 2-bank interleave so if possible, set it to 4-Bank. Use 2-Bank only if you are using a single 2-bank SDRAM DIMM. Note, however, that Award (now part of Phoenix Technologies) recommends that SDRAM bank interleaving be disabled if 16Mbit SDRAM DIMMs are used. This is because early 16Mbit SDRAM DIMMs used to have stability problems with bank interleaving. All SDRAM modules can now use bank interleaving without stability problems."
sounds good, but im not sure ;x
