Ok, where should I start? I've only been having headaches with this monitor.
Alright, let's start with gaming issues:
Issue 1: I've been testing Lord of the Rings Online open beta, and playing on my 15" LCD (VGA connection), everything is fine. A couple weeks ago, I received my new Dell 2007WFP, am using it on a DVI connection. After playing LOTRO for about 10 minutes (running at 1050x1680 [same resolution as set on monitor] in windowed mode) my monitor goes into sleep mode. Pressing the power button to turn it off, then turning it back on, the monitor now says "The monitor is no longer receiving a signal from your computer. Move your mouse or press a key on your keyboard to wake it up [or something similar to this]". Of course, trying to wake it up in this method does nothing, and the monitor goes into sleep mode again. My only option is to completely shut off my computer, wait a minute, then turn it back on, and everything resumes operation. IF I only do a soft restart of the computer, the monitor stays in sleep mode until Windows COMPLETELY loads, and it either might come back with a signal, or if I physically unplug the monitor again and plug it back in, the picture comes back. VGA isn't working either, which I will explain now.
Issue 2: Switching to a VGA connection, when my computer is booting (from a cold start), the POST and windows loading screen displays fine, but right after the Windows loading screen completes, the monitor goes blank and says something to the effect of "Monitor is out of range. Set to 1050x1680 at 60hz". Odd thing is, before when I was on DVI, this is the exact resolution and default refresh that it was set to. Even unplugging the DVI cable (while using VGA) from my computer and monitor doesn't help anything.
Issue 3: While using only DVI connection, if I do a soft-restart of my monitor, POST does not display. POST only displays on a cold boot, very annoying.
All of these issues relate to each other it seems, and HELP is greatly appreciated. This is ticking me off. I thought this monitor was supposed to be godly?
